AI智能索引来源:http://www.mr2.com/forums/threads/100057-Electronic-speedometer-not-working-electrical-problem
Electronic speedometer not working, electrical problem?
speedometer, cluster, working, odometer, instrument, splice, frunk, plug, connected, wire, checked, electronic, fuse, thought, work, swapped, previous, owner, problem, km/h, speed, engine, fine, back, quit, happen, stopped, suddenly, replaced, burned, ecu-b, speedos, wires/plugs, discovered, exact, crappy, lead, tubed, confused, soldered/shrink, idea, swapping, directly, sensor, weird, screws, highly, unplugged, process, slightly
    I have a 1991 MR2 turbo. A previous owner had swapped in a 1994 3sgte engine, transmission, and instrument cluster (so it has the electronic speedometer). It was working fine but the speedometer was in km/h and the speed limits here are in mph. So I bought a replacement instrument cluster that was supposed to have been for a 93-99 mr2, but the wiring on the back of it was slightly different than the one I had and it didn
