AI智能索引来源:http://www.mr2.com/forums/threads/100232-Boost-leak-testing-be-carfull
3S-GTE USDM Turbo Engine Boost leak testing be carfull
3S-GTE USDM Turbo Engine, boost, leak, showing, clear, realize, carfull, testing, correct, leaks, check, show
    Hey guys wanted to give everyone a heads up on testing for boost leaks make. I blew my cam seals out doing a leak test so be carfull when doing leak a leak teat. Make sure you pull the oil cap off to take the crank case pressure out Sent from my SM-N900V using Tapatalk
