AI智能索引来源:http://www.mr2.com/forums/threads/101288-Overheating%21%21
3S-GTE USDM Turbo Engine Overheating!!
3sgte, overheating, sw20, 3S-GTE USDM Turbo Engine, drained, gonna, started, boost, past, radiator, coolant, flush, week, options, waterpump, checked, headgasket, compression, good, brown, block, turned, ideas, advice, greatly, appreciated, connected, check, setup, stock, clamps, couplers, notice, fans, tank, flow, coming, fine, filled, system, cooling, bled, steam, sudden, drive, road, permit, finally, safety, inspected
    So I finally got my permit to drive the car on the road to get it safety inspected. Do a few pulls no problems. Then all of a sudden I get steam coming out of the coolant over flow tank!! Fans are fine. I drained, filled and bled the cooling system twice. Still overheating after about 10-20 min. Left the cap off and started the car and started shooting out of the filler neck. I removed the thermostat and blocked off the hoses to the heater (I
