AI智能索引来源:http://www.mr2.com/forums/threads/103994-my-mr-needs-assistant-help-pleaseeeee
my mr needs assistant help pleaseeeee
stock, found, 125uu, 5sfe, distributor, bump, update, soldered, pigtails, pleaseeeee, assistant, rotor, realize, junkyard, ignition, coil, grabbed
    starting from the beginning. I got off the highway, my car is blowing smoke. my hose broke and coolant is pissing all over the place. so I replace one, poured in coolant and more leakage. found another hose that broke but it was under the distributor. so I had to remove the cap and rotor off to get under it. replaced that hose. and then I noticed the harness that plugs into the distributor is worn and corroded. it snapped. I got a replacement from the junkyard, solder the two ends together.
