AI智能索引来源:http://www.mr2.com/forums/threads/104263-cause-for-wheel-coilover-clearance-difference-from-left-right
cause for wheel/coilover clearance difference from left/right.
side, drivers, coilover, clearance, screech, spacer, wheel, pass, time, front, twosrus, 12.4?smallest, maxed, plates, bolts, crash, sells, full, evertime, pains, hear, noise, rash, causing, camber, problem, expected, ground, level, fingers, difference, wheel/coilover, left/right, parked, check, setup, coils
    On drivers side i have about 3mm clearance but on pass side i have about 8. i can get my fingers in between wheel and coilover on pass side. i expected maybe ground level so where ever i parked i would check clearance and the drivers side was always about 3mm away from coilover. any one else run into this problem? my setup bc coils with 17 x 8/9 +35 all with camber plates maxed neg and 12.4?(smallest cb twosrus sells) crash bolts full pos a 5mm spacer up front too. had a 3mm spacer but would
