AI智能索引来源:http://www.mr2.com/forums/threads/104454-3rd-gen-fuel-system-limits
3S-GTE JDM 3rd Gen Turbo Engine 3rd gen fuel system limits?
3S-GTE JDM 3rd Gen Turbo Engine, fuel, engine, system, pressure, injectors, 400hp, boost, power, cycle, support, duty, engines, lower, work, significantly, bsfc, making, flow, wheel, flywheel, needed, factors, 12psi, high, estimated, 4cylinder, per-hp, 515cc, 63psi, 20psi, case, 375~400hp, stock, personally, higher, push, remember, 550cc, minimum, limits, show, assuming, typical, 55psi, ratio, rise, identical, 3sgtes, systems
    Can someone tell me what the limits of the 3rd gen
