AI智能索引来源:http://www.mr2.com/forums/threads/104786-Help%21%21-electrical-issues
5S-FE MK2 Non-Turbo Engine Help!! electrical issues
5S-FE MK2 Non-Turbo Engine, lights, compartment, screw, contact, made, disconnect, relays, work, electronics, start, turn, connected, alternator, crank, wire, door, plzzz, advice, 35715, starts, cockpit, head, cars, info, replace, front, background, issues, electrical, dumbass, forgot, short, replaced, body, relay, connects, battery, reconnected
    OK so to start of just a little background info. i was trying to replace some relays in the front compartment of my mr2, but my dumbass forgot to disconnect the battery. The screw that connects the FL ALT 120 relay made contact with the cars body and there was a short. I replaced all the relays in that compartment but now after everything was reconnected the car won
