AI智能索引来源:http://www.mr2.com/forums/threads/104897-Could-the-O2-sensor-be-damage
5S-FE MK2 Non-Turbo Engine Could the O2 sensor be damage...
5S-FE MK2 Non-Turbo Engine, read, smoke, sensor, idle, black, rich, doubtful, correction, noticeable, small, typically, focus, impact, amount, injects, fuel, temp, trans, pulled, water, requires, idling, check, light, engine, loop, closed, damage, notice, n/as, codes, refer, clip, paper, thin, solid, conductive, electrically, explanation, simple, item
    Own a 92 MR2 N/A - don
