AI智能索引来源:http://www.mr2.com/forums/threads/105135-Help%21-Electrical-issus
Help! Electrical issus
wires, engine, fried, battery, lights, checked, wire, perfectly, harness, trace, discontinuity, corrosion, fine, problem, give, parts, sell, idea, fuses, check, start, pressed, turned, clutch, places, issus, electrical, connected, proper, ground, entire, reconnected, power, gauge, disconnected, shut, electricity, frunk, turning
    I installed a gen3 3sgte two years ago from a gene 3sgte. Everything ran fine before and after the swap. After 2 years of driving with the gen3, the electronics started giving out. After initially installing the motor, the gauge on the dash read a low voltage of the batter but the battery still read 10-12 volts while the car was running using a voltage meter. One day I
