AI智能索引来源:http://www.mr2.com/forums/threads/106267-T-Tops-Leaking-Still
T-Tops Leaking....Still
seals, water, drains, looked, checked, flowed, silicone, check, problem, replace, bottoms, preferred, leaking, mine, rear, vehicle, t-tops, completely, jamb, inside, door, rotted
    So my tops have been leaking since I got the car, mostly the passenger side. Was leaking at the front corner at the window onto the seat. Driver side was leaking slightly at the rear corner onto my seatbelt and into the carpet behind the seat. After trying the grease from honda and the eccentric top guides they helped a little bit, but it eventually started leaking more. So at the start of the summer I ordered all new top seals to the sum of something around $500 and lo and behold now that here
