AI智能索引来源:http://www.mr2.com/forums/threads/108360-Fuel-pump-questions
3S-GTE JDM 3rd Gen Turbo Engine Fuel pump questions??
3S-GTE JDM 3rd Gen Turbo Engine, fuel, tank, line, pump, lines, kinked, greatly, appreciated, cuts, general, connected, error, replace, poorly, directly, experience, mr2s, drop, process, kind, fittings, swapped, turbo, questions, replaced, hard, sends, main, engine, starts, rethread, unthread, idles
    Hello, i just replaced my fuel pump on my 91 turbo swapped mr2 but in the process i kind of kinked the fuel line that has the fittings on it. Its one of the only hard lines that come from the fuel pump on the tank and that you would have to unthread and rethread to drop the tank. i believe it is the main fuel line that sends fuel to the engine and now the car starts and idles very very poorly and even cuts off sometimes. Can a kinked fuel line do this? If so how can i fix it because its one of
