AI智能索引来源:http://www.mr2.com/forums/threads/109102-Intermittent-check-engine-light-at-higher-RPM
3S-GTE USDM Turbo Engine Intermittent check engine light at higher RPM
3S-GTE USDM Turbo Engine, engine, light, check, order, replacement, sensor, coolant, temp, boost, helps, edit, seconds, cold, codes, yesterday, intermittent, higher, times, code
    I had my car out on the track the other day and during the first few session when the car was at higher rpm 4000-6000rpm I would have the check engine light come on for a few seconds. There was no hesitation or misfire while the light came on. It wasn
