AI智能索引来源:http://www.mr2.com/forums/threads/109424-transmission-problem
5S-FE MK2 Non-Turbo Engine transmission problem
clutch, pedal, transmission, 5S-FE MK2 Non-Turbo Engine, slave, updated, matters, loss, work, ground, battery, connected, reinstalled, note, resistance, cylinder, back, problem, swapped, putting, press
    I swapped out the clutch and after putting it back on along with the slave cylinder, the clutch doesn
