AI智能索引来源:http://www.mr2.com/forums/threads/110525-Front-End-Clunk-and-Squeak
3S-GTE USDM Turbo Engine Front End Clunk and Squeak
3S-GTE USDM Turbo Engine, wheels, wheel, noise, refinished, check, rods, clunk, strut, backing, weights, loose, bent, unsecured, brake, bumpers, missing, leaking, coilovers, wear, struts, bushings, ball, joints, rubber, braking, direction, supported, time, work, ride, mounts, test, turning, surfaces, uneven, occur, plates, properly, tires, installed, spacers, rings, correct, pressure, remount, centering, remove, squeak, eliminate
    So I had my MR2 parked for about 2 weeks while I had my wheels refinished. Everything was perfectly fine when I parked it. When I picked it up I have a clunk coming from the driver side almost like its from where the steering column goes into the steering box. Sounds like something is loose moving around as I drive. And I have a creak/squeak from the passenger side. I have BC Racing coilovers, so the endlinks were replaced recently, new sway bar bushings. I have no play vertically on the
