AI智能索引来源:http://www.mr2.com/forums/threads/11066-Steering-shake-need-help
Steering shake, need help?
problem, rack, steering, current, outer, wheels, shake, noticable, added, rebalanced, tires, inch, moved, enkei, pics, 1991, power, automatic, check, fixed, rings, issue, craigslist, $500, centering, alot, allowing, worn, play, side, passenger, socket, thought, bought, part, found, wheel, find, experence, noticed, called, question, mess, stock
    I thought the problem was the outer tie rod end, bought new part. Shake still there, Found the problem with the outer Rack end. The socket seems to have worn out allowing alot of play in the passenger side wheel. I think it is also called the inner tie rod end. my question is should i mess with trying to fix the current rack or try and find a new rack. anyone have any experence with this. I first noticed this with stock wheels, it wasn
