Warning: SimpleXMLElement::asXML(E:\phpstudy_pro\zhinengdaohang\sitemaps\sitemap_126.xml.tmp): failed to open stream: Permission denied in E:\phpstudy_pro\zhinengdaohang\dd.php on line 1330
How much do cold temperatures affect precision measurements? - AI智能索引
AI智能索引来源:http://www.mr2.com/forums/threads/111579-How-much-do-cold-temperatures-affect-precision-measurements
measure, bore, shrink, roughly, worst, scenario, case, diameter, piston, rough, clearance, wrong, measuring, 0.0007, adds, input, 0.001, 0.0006, walls, thickness, reading, numbers, 0.0001, 30°f, in/°f, 6.5x10^-6, expansion, long, thermal, coefficient, temperatures, cold, affect, precision, steel, measurements, .000195, smaller, feeling, worry, difference, inch, pretty, takes, temperature, colder, precise, equipment, thousandth, 10th
    I have basically no choice but to rebuild an engine outside in the cold. I
