AI智能索引来源:http://www.mr2.com/forums/threads/111696-CEL-42-Speed-sensor-question
CEL 42 Speed sensor question
signal, working, speedo, speedometer, generate, pulse, transistor, sensor, wiring, cruise, gen3, question, requires, directly, ground, outputs, square, adding, resistor, hooked, wave, reason, proper, start, good, hooking, resistors, faulty, panel, instrument, free, code, pull, basically, pulsed, works, running, mine, speedos, times, 8-9psi, boosts, 13-14psi, found, manual, driven, cable, boost, limits, engine
    So I have 91 to Gen3 swap using Gen3 engine and body harness. I have JDM chipped ECU. Every now and then I get CEL 42 and that limits the boost to 8-9psi with the CEL on. Most of the times it goes away and car boosts to 13-14psi. Speedometer is working and it is cable driven manual sensor. This is what I found in earlier discussions
