AI智能索引来源:http://www.mr2.com/forums/threads/112286-Power-Steering-ECU-capacitors-Guide
Power Steering ECU capacitors - Guide
capacitors, 47uf, remove, solder, board, screws, joints, rated, steering, power, replace, plastic, disconnect, guide, connector, white, rubber, electrolytic, aluminium, inside, arrows, lining, cables, electrical, cracked, arrow, 10uf, chemicon, quality, good, paste, nippon, rubycon, panasonic, temperature, 105c, 4.7uf, nichicon, motor, computer, boards, glue, 1999, driver, voltage, housing, heatsink, conductive, underside, thermally
    Hi, I couldn
