AI智能索引来源:http://www.mr2.com/forums/threads/112822-Would-ECT-or-MAP-Sensor-Cause-Not-Starting
5S-FE MK2 Non-Turbo Engine Would ECT or MAP Sensor Cause Not Starting?
5sfe n/a mr2, 91, etc sensor, map sensor, wont start, 5S-FE MK2 Non-Turbo Engine, frayed, ground, wires, broken, distributor, time, fired, mended, connection, starting, solved, sensor, problem, turned, harness, wiring
    Hi everyone, I have a 91 5sfe that was running great. All of the sudden it started running rough, then died. Got it started and was able to get it off the road. Now the car will not hardly start, when it does it runs really rough and wants to die. I have to almost floor it to get it to 3000 rpm and it blows black smoke and smells like gas. I pulled the codes and got 22, 25, 26 and 31. I ordered a map sensor, but was wondering if the ect sensor could cause these problems. Any help
