5S-FE MK2 Non-Turbo Engine 72 PSI Fuel pressure... How?
5sfe, fuel, fuel pressure regulator, fuel pump, fuel system, 5S-FE MK2 Non-Turbo Engine, pump, pressure, rail, regulator, test, drop, hose, engine, wire, water, dvom, outlet, wiring, voltage, fprs, problem, v-drop, running, waiting, coolant, locking, specs, errant, flow, long, thin, broken, return, position, disconnected, jumped, conditions, connection, experience, jumper, good, diagnosis, stuck, drawing, sounds, current, result, range, flashlight
What could cause fuel pressure, measured at the fuel filter, to be 72 PSI!? (Spec: 38-44 PSI @ Fuel Rail)
Firstly, I rented a fuel pressure gauge and did some tests that I dont feel entirely confident about. I returned the tool and have sent away for my own kit so I can do extensive testing both at the fuel filter and especially at the fuel rail (after the pulsator, in the same atmosphere as the injectors). I have a few days before it gets here, and have a lot of learning to do about fuel
