Warning: SimpleXMLElement::asXML(E:\phpstudy_pro\zhinengdaohang\sitemaps\sitemap_125.xml.tmp): failed to open stream: Permission denied in E:\phpstudy_pro\zhinengdaohang\dd.php on line 1330
Warning: SimpleXMLElement::asXML(E:\phpstudy_pro\zhinengdaohang\sitemap_index.xml.tmp): failed to open stream: Permission denied in E:\phpstudy_pro\zhinengdaohang\dd.php on line 1256
3S-GE JDM Non-Turbo Engine Constant Ticking before trying to fire engine - AI智能索引
AI智能索引来源:http://www.mr2.com/forums/threads/113794-Constant-Ticking-before-trying-to-fire-engine
3S-GE JDM Non-Turbo Engine, fuel, fire, engine, ticking, constant, rail/injectors, back, remove, thoughts, plugs, spark, smell, appreciated, problem, ground, wires, properly, re-attached, checked, thought, turns, inclination, real, today, decade, thing, removed, dead, pump, noted, find, 1990, picked, g-limited, barn, tank, replaced, putting, position, coming, noise, rapid, loud, finally, injectors, fine, works, inlet, clean
    my son and I picked up a 1990 G-Limited Mk2 a while back. Was an old barn find that hasn
