HomeCustom Illuminated MR2 Name PlatesCustom Climate Control Lightinghttp://blog.myspace.com/42473469Custom Illuminated MR2 Name PlatesCustom Climate Control Lightinghttp://blog.myspace.com/424734691mz build and install blogToyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
cable, throttle, great, stuck, problem, make, definetly, lubricate, times, time, normal, drops, park, $560, replaced, gasket, timing, belt, seals, back, showed, issue, wd40, idle, messing, control, screw
- i just got a new timing belt all the seals and the oil pan gasket replaced. for like $560. and the throttle cable gets stuck but i didnt know it at first then i took it back up there after messing with the idle control and i got the screw all the way down. and it wasnt low enough. so they showed me it was getting stuck. so the used some wd40 and tried to lubricate it. it didnt do tat great of job. anyone know what else i can use that will definetly make this problem go away. i mean when i rev
