HomeVisit Homepagehttp://www.injector.com/faq.phpwww.DJKiddquikk.comwww.myspace.com/chrisschnellToyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
injector, fuel, injectors, flow, engine, cycle, duty, time, test, 100%, static, rate, pintle, injection, marren, amount, control, open, impedance, computer, conditions, customer, injectors, performance, electrical, electromagnetic, exchange, miles, service, properly, operating, wide, coil, internal, running, pressure, components, serviceable, tests, parts, millisecond, determine, hour, low-impedance, high-impedance, manufacturers, ohms, actual, ground, minute
- How does a fuel injector work?
A fuel injector is nothing more than a high-speed valve for gasoline. An engine computer or controller is used to control the fuel injector. Contrary to popular belief, this is NOT done by sending power to the injector. Fuel injectors are normally fed power whenever the ignition key is on. The computer controls the negative, or ground side, of the circuit. When the computer provides the injector with a ground, the circuit is completed and current is allowed to
