AI智能索引来源:http://www.mr2.com/forums/threads/15036-coolent-loss
pressure, problem, coolant, bleeder, found, coolent, test, swap, loss, radiator, slight, coldsome, running, temp, dyno, question, banghead, confused, tightened, normal, screw, figure, head, mech, year, scratch, 3sgte
    ok got a slight problem. i have had my 3sgte swap in my car for about a year now, and have had a coolant loss problem even before the swap. i have had one of the best mech i know even scratch his head trying to figure it out tried a pressure test . well just the other day we found where it was going. when under pressure and the coolant at normal running temp (did the pressure test with the coolant cold)some how its getting out through the bleeder on the radiator. found this out while on the
