HomeVisit HomepageVisit HomepageToyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
stock, supra, sensor, system, setup, exhaust, compression, impedance, injectors, intake, 550s, choice, onlygives, denso, wizard, cams, range, manifold, tdo6-, wrong, correct, suposet, turbocharger, voltage, battery, offsets, change, rescale, injectoer, high, current, select, eliminate, changed, pack, resistor, pistons, ratio, port, spark, 8.51, adjustable, straight, settings, gear, street, full, custom, copper, 3bar
- My current setup is:
Cams oem
Intake Manifold oem
Turbocharger TDO6- 20G
Fuel system; Supra 550
