AI智能索引来源:http://www.mr2.com/forums/threads/21466-5s-throttle-sticking
5s throttle sticking
throttle, sticking, spring, stiff, return, curious, 4,000, pretty, idle, normal, types, oils/grease, sprays, synthetic, including, everytime, guys, wd-40, problem, found, taking, solution, easier, times, year, bought, 2,000, roughly, 5sfe, good, anymore, clean, grease, easy, lube, push, harder, starts, spray, thicker, fine, works, weeks, oil/grease, cold, idled
    I have the good ol 5sfe in my 2. But anymore the throttle keeps sticking at roughly 2,000 rpm. I have taken it off probably about 50 times since i first bought it over a year ago to clean it up. When i take it off and grease it up it works fine for a few weeks, but once it gets cold it gets stiff (obviously oil/grease gets thicker). When i first take it off and spray any lube on it the throttle is easy to push, but then it gets harder with more use an starts sticking idled up. If you rev it to
