AI智能索引来源:http://www.mr2.com/forums/threads/22347-PreMixing-Good-Bad-No-Idea
PreMixing? Good, Bad, No Idea?
engine, 2-cycle, premixing, thing, working, stop, good, piston, write, question, guys, leave, residue, chamber, combustion, clean, feel, burns, mind, answer, tank, fill, community, called, dump, ounces, rotory, removed, insures, idea, rx-7, injectors, practice, common, llubricated
    There is a common practice in the RX-7 community... It is called premixing... It is where you dump about 16 ounces of 2-cycle oil in the gas tank before every fill up... This is because the rotory engine has oil injectors and they stop working or are removed... This insures that if they stop working the engine is still llubricated well... My question is, do you guys think this would be a good thing or bad thing to do with the piston engine... Please write your answer and why you feel the
