AI智能索引来源:http://www.mr2.com/forums/threads/23581-ignition-timing-HELP%21
ignition timing HELP!
distributer, advance, degrees, timing, great, asap, wrong, direction, turn, crank, ignition
    i need to know which direction to turn the distributer to advance the timing i crank it all the way to advance it and i cant get it to 10 degrees BTC i can only get it to 7 or 8 degrees BTC is there a way that it could be the wrong distributer? if anyone can help asap that would be great thanx
