Homethis threadherehttp://mr2.zhinengdaohang.com/com/forums/mk-2-mr2-s...umper-etc.htmlToyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
light, pre-wired, taped, fuse, frunk, wrong, harder, wired, including, system, harness, harnesses, wiring, lights, relay, find, clips, front, fogs, write-up, foglight, thought, mr2s, switch, clip, panel, positions, non-prewired, plug, dash
- I wrote this up last year and just joined this board not too long ago so I wanted to share this with you guys.
Well a lot of people have been asking how to install fogs on a non-prewired MR-2 (most likely a 91) and so I thought a write up was needed
First: to verify you do not have the wiring harness, look in the main fuse box under the hood and look for the location of where the fogs relay would be. You can also look in the gap where the fog lights should sit and if you find a wire
