AI智能索引来源:http://www.mr2.com/forums/threads/26020-3s-Eagle-Rods-on-5s-Crank
3s Eagle Rods on 5s Crank
crank, rods, journals, guys, ground, integrity, grind, weaken, align, correctly, holes, bearings, measurements, skeptical, eagle, knew, grinding, 52mm, diameter, 50mm
    Hey guys. I knew that the crank had to be ground to fit the 3s rods. But, what I didn
