AI智能索引来源:http://www.mr2.com/forums/threads/26558-dead-battery-Alternator
dead battery Alternator????????
back, volts, alternator, battery, volt, 12.6, meter, found, 12.7, 12.8, 12.3, running, voltage, regulator, ground, poor, 11.8, good, month, optima, yellow, driver, started, summer, fall, putting, dead, turned, charging, start
    I had not started my 2 since mid fall (summer driver only) and the six month old optima yellow top battery was only putting out 9 1/2 volts hardly enough to start the 2. After charging it back up to 13 i set it back in the car and she turned right over. Then I used my volt meter and found (with the car off) my the volt went from 12.8 to 12.7 to 12.6 and so on. Now with the car on I
