Homewww.kgparts.comVisit Homepagewww.KentsVision.comwww.KVStudios.comwww.InnerGaming.comToyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
idle, sensor, engine, thing, vaccuum, high, problem, lower, 2000rpm, afternoon, working, valve, 1100rpm, cleaned, replacing, suggestion, appreciated, greatly, leaning, 24iat, code, light, irregular, check, idea, idlearound, 1100, swap, wondering, site, throttle, couple, smogged, days, passed, good, timing, leak, bodies, lines, spot, starts
- hi, i am new into this site, just wondering if anyone has any idea what causes for high idle(around 1100 rpm), just did an engine swap, have tried 3 different throttle bodies and all did the same thing, no vaccuum leak, vaccuum lines are all in the right spot, timing is good, i had it smogged a couple of days ago and passed without any problem, idle normally starts up at around 2000rpm and wouldn
