HomeVisit HomepageSV3Power cat-back exhaust for NA AW11s now available! It's a thing!Follow SV3Power on Facebook for new product updates + extrasToyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
valve, cant, vacuum, figure, lines, line, manifold, body, throttle, coolant, pipe, engine, fitting, connections, metal, numerous, make, find, rear, connected, connects, separate, final, manuals, fittings, pictures, clarification, ill, send, items, post, filling, speed, aspirated, part, figured, nipples, plugged, fuel, bypass, large, 1989, dont, smaller, left, mounted, switching, side, confirm, pressure
- I need some help to make the final connections for coolant and vacuum lines on my 1989 MR 2, normally aspirated, 5 speed. I have figured them all out except for the following:
On the manifold there is a fitting with 3 nipples; 1 is plugged, 1 goes to the valve for the fuel pressure, cant figure out where the third goes.
On the throttle body there are 2 coolant connections; 1 goes to the bypass line below it; can
