Fuel Injector Problem? Any Help Is Good Help.
injector, wire, time, found, guess, grounds, grounded, spray, great.confused, guys, sence, harness, makes, striped, injectorthe, no.2, tracked, spraying, causing, coming, rich, good, problem, post, running, exhaust, side, fuel, switch, color, solid, onthe, light, noid, spun, plugs, pulled, checked, stripe
I had a post on here about my MR2 running like $h*t, and I think I have tracked it down to my no.2 injector. The injector is spraying all the time causing it to be so rich that gas is coming out the exhaust. I found it when I pulled all the plugs and spun it over. After that I checked it with a noid light and found it to be on all the time. I no one side of the injector gives me 12v when I switch it on(the solid color) and the stripe wire goes to the ECU. I
