AI智能索引来源:http://www.mr2.com/forums/threads/28805-Some-Problems
door, open, weak, brakes, hand, brake, working, problems, on[like, buzzalarm, lights, turn, failing], supposed, ignition, [sounds, leave, keys, passanger, headlights, range, fine], brights, [not, horn, sounds, [replacing], wrong, park, button, alarmnot, stop, replace, make, noise, slow
    There is something wrong with my hand brake. i dont really use it cause i park in 1st..but you never know when you might need it. i dont know if its the brakes or the hand brake itself. Most likely i
