Home1mz build and install blog1mz build and install blogHow to bleed car brakesToyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
step, brake, fluid, screw, corner, repeat, bleeder, wrench, pedal, line, pressure, drivers, reservoir, hard, friend, vacuum, jack, rock, full, check, rear, passenger, open, process, spray, front, yells, bubbles, coming, pedalboy_01, wheels, make, stands, remove, brakes, sucked, ensure, falling, back, nuts, break, flush, caustic, extraordinarily, wd-40, caliper, rinse, directions, fills, loose
- The easiest way to do it is with 2 people.
Tools:
Jar for fluid (I use spaghetti sauce jars, ymmv)
2-3
