HomeVisit Homepage1mz build and install blogToyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
body harness, wire, turn, relay, question, keys, connected, gauges, turbo, timer, harness, body, runs, true, lines, drivers, evey, accessories, position, inch, holds, kick, upper, connector, white, blew, fuses, underneath, regulate, silver, centered, fuse, panel, seat, function, turns, pulled, positionengines, counts, rapid, alot, hear, fans, battery, worked, installing, working, issues, wanted, make
- Ok, so I was working on installing my turbo timer, and I wanted to make sure the parking brake feature worked so I connected my battery, turn my keys to the on position(Engine
