Home1mz build and install blogImage hosting, free photo sharing & video sharing at Photobucket1mz build and install blogHantavirus1mz build and install blogVisit HomepageToyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
balls, trunk, clean, doin, wanna, plastic, components, especialy, problem, pull, wich, moth, mice, advice, pointers, experiance, make, words, slight, helpundecided, cars, diffrence, fast, speeds, noises, picky, makin, ruin, clip, works, housing, extremely, things, suggestions, high, crack, somethins, bend, clogin, easy, pullthe, hosing, pullin, plug, bottom, electric, unplug, drain, consist, hedge
- I stored my car over the winter and had mice inhabit it. I put moth balls and hedge balls all over and still the ate the moth balls and shitted it out in my car. I had ta clean out the front trunk compartment but am plannin of doin a thorough clean wich I think might consist of pullin th plastic out and hosing the trunk and components down( I will pullthe plug in the bottom of the trunk for it ta drain) then dry it out (especialy the electric components) and I will unplug the battery while doin
