AI智能索引来源:http://www.mr2.com/forums/threads/32466-Transmission-Fluid-Questions
Transmission Fluid Questions.
bolt, fill, transmission, draining, fluid, start, people, manual, 5sfe, tranny, work, correct, pump, sort, tomorrow, tranmission, drop, button, side, turning, things, bolts, oils, found, searched, check, double, working, questions, 1991, girlfriends, syncromesh, pretty, drain, process, obvious, filling, clearify, quarts, front
    Working with a 1991 MR2 5SFE (Manual Transmission) Just doing some work on my girlfriends mr2. Just want to double check things with people before I start turning bolts and draining oils. I searched and found people use Syncromesh transmission oil for their tranny, and the car will take 3-4 quarts. Now just want to clearify the draining, filling process. I see the drain bolt, its pretty obvious. As far as the fill bolt goes, on an NA 5SFE its on the front
