AI智能索引来源:http://www.mr2.com/forums/threads/34200-Need-help-with-possible-purchase
Need help with possible purchase.
gasket, belt, alternator, head, thermostat, stock, replaced, springs, clips, retainers, seals, manifold, intake, timing, cover, valve, exhaust, valves,valve, housing, waterpump, stem, attainable, problems, cars, phillip, input, driver, daily, tested, compression, point, reliable, hopes, parts, buying, things, found, area, turbo, information, purchase, forum, give, hoping, 67,000, miles, father, sellers, appears, maintenance
    Hello everyone, I am new to the forum, and was hoping some of you could give me some information on things I should look for in buying a used Mr2. I found a 91 turbo around my area with 67,000 miles for a good deal, or atleast what I think is. Car is totally stock, and carfax is clean. Owner is its second, the first being the sellers father. Car APPEARS to be well taken care of. Maintenance done to this point is -Head gasket -Valve cover gasket -Timing belt -Intake and exhaust manifold
