HomeLogin to a private Photobucket.com albumToyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
timing, closest, intake, dead, exhaust, open, cams, pistons, gear, belt, comparison, find, i.e.-cyl, supposed, writeup, confuse, advance, picture, seagulls, flock, back, valves, time, finishing, side, starting, happen, yesterday, began, effered, flywheel, connect, teeth, lines, wierd, skipped, possibly, center, thought, order
- ok so i began to do my timing belt yesterday and got it all effered up, i cant say wat happen all i can tell you is wat it looks like now! ok so here goes...right now pistons 1 and 4 are closest! (1 starting on the timing belt side, 4 being closest to the flywheel) not at, but closest to top dead center...now, my exhaust cam is currently about to open on #1 then 3 then 4 then 2 my intake cam is currently finishing 4 then going to open (in this order) 2, 1 , 3, my thought is that i possibly
