washers, thrust, crank, swap, bottom, block, build, wore, large, factor, opinions, month, correctly, recall, rods, intactpan, common, parts, pistons, recycle, work, worth, salvaging, week, figured, glitter, spread, decentegrated, years, give, pulled, garage, knocking, thought, replaced, call, blocks, figure, problem, question, side, back, bearings, knock, amature, obvoiusly, continued
So I have my old 5S bottom end in my garage. Before I did a block swap I was getting some knocking. I pulled the pan and the Thrust Washers were decentegrated and spread out like glitter through the pan. This was years ago, btw. I didn
