AI智能索引来源:http://www.mr2.com/forums/threads/35131-Clutch-issues-help%21
Clutch issues, help!
clutch, problem, pressure, change, taking, master, cylinder, depressed, bleed, gears, read, untill, fluid, comming, worth, tldr, appreciated, greatly, hold, quickly, hand, fast, ideas, specific, picking, fixed, intersection, bought, peddle, held, reference, 3sge, list, issues, ending, sw20, 1990, manual, lost, slowly, move, rode, issue, time, outa
    Hi Again I have a problem with my 2, the list seems never ending. I have a Manual 1990 SW20 3SGE for reference. The two has had a problem with the clutch since I bought it, if you held the clutch peddle down for a while it lost pressure, this was never an issue. For the first time ever I ran outa gas in the 2, I rode the clutch a lil to get off the intersection. After I got it going again if I depressed the clutch slowly there was NO pressure at all to move the clutch. If I did it fast
