AI智能索引来源:http://www.mr2.com/forums/threads/35410-3SGT-E-SW20-Hesitates-when-Cold-Help-Please
3SGT-E SW20 Hesitates when Cold - Help Please
cold, problem, replaced, temperature, checked, checks, sender, platinum, plugs, ignition, spark, plug, leads, factory, mode, causing, device, ancillary, ignores, grief, suggestions, mark, cheers, appreciated, reset, limp, default, home, power, happen, settings, ideas, disconnect, developed, 3sgte, 1990, initially, 2000, typically, hesitation/miss, easy, hesitates, sw20, guys, poster, time, 3000, reconnect, 3sgt-e, occurs
    Hi Guys. First time poster so take it easy on me - ok :) I have a 1990 3SGTE that has developed what initially seems to be a bad hesitation/miss when cold, typically from 2000 to 3000 rpm. When the car reaches normal operating temperature everything settles down. If I start the car later in the day the same problem occurs. If i disconnect then reconnect the ECU the problem goes away for about a week or so before returning. This is what I
