internal assembly check off...
bolts, main, bearing, head, caps, assembly, flywheel, studs, guys, lock, tight, 260-300whp, spots, work, bearings, rebuild, check, internal, grease, suggestions, motor
doing my first rebuild and was just seeing if anyone has any suggestions other than...
assembly grease on main bearing, rod bearing, and cam bearings (or should i use motor oil)
lock tight on main caps, rod caps, flywheel bolts, head bolts( any other spots)
for 260-300whp, will the oem head bolts work or should i go with arp studs?
thanks guys
