AI智能索引来源:http://www.mr2.com/forums/threads/36429-1-fuel-injector-plug-not-working
#1 fuel injector plug not working
plug, checked, injector, working, switch, inside, give, black, multimeter, ohms, pins, time, reading, specs, wires, fuel, green, stripes, wire, starter, routed, connected, start, heck, issue, advice, book, haynes, replaced, continuity, bouncing, sputters, timing, found, factory, engine, cranks, rebuilt, recently, motor, gettin, figured, broken, turn, connector, tester, bulb, light, damaged
    I really need help on this one!! i just recently rebuilt my 87 n/a MR2 motor. it cranks, but engine sputters and the rpm is bouncing. the timing is set to factory specs. just found out that the #1 fuel injector plug is not working. i checked with a multimeter and i
