door, tool, adjustment, lower, normal, position, adjust, photo, long, loose, difficult, bolt, block, appreciated, give, clue, hinge, smaller, makes, attached, left, larger, manaul, indicating, special, required, service, adjusted, vertically
Hi, anyone try to adjust the door vertically? As you can see from the photo I attached, the gap of the lower left is larger than the normal. I can see the gap of the lower right is smaller than the normal too, it makes me believe the position of the door has to be adjusted. The service manaul indicating a special tool is required to do the adjustment, I have the tool already but it is difficult to loose the bolt because the tool is not long enough and the hinge of the door is a block.
