AI智能索引来源:http://www.mr2.com/forums/threads/3721-Stock-internals-24-psi
Stock internals + 24 psi =
boost, stock, spring, controlling, turbos, motor, cams, controller, davidv, solenoid, spooling, opens, cutting, http://www.mr2board.com/files/davidv/graph_20060206095241_00001.jpg, internals, 7,000, easily, alas, redline
    http://www.mr2board.com/files/davidv/graph_20060206095241_00001.jpg This is controlling off the WG spring and as you can see, cutting the run at 7,000 rpm. At redline, it would have been over 400 whp easily, but alas, right now I am only controlling boost off the WG spring. Once I can get a boost controller solenoid that can keep up with the turbo
