AI智能索引来源:http://www.mr2.com/forums/threads/38179-A-Note-on-Starters
A Note on Starters
starter, tested, noticed, start, battery, cables, turned, parts, shut, issues, manual, garage, test, armature, good, taking, process, power, bearings, feeling, adequate, stand, recoated, reassembled, grease, section, carbon, performed, continuity, sand, lightly, places, grit, sandpaper, tests, forum, passed, satisfied, lazy, sticky, commutator, outlined, service, downloaded, clean, issue, maintenance, routine, repairs, cash
    Many of you may have seen me helping people figure out electrical issues with their dueces and yesterday I had a good one that I thought I would share with all of you. The other day, I noticed my car leaking coolant in a parking lot. Nothing major, it just turned out that it was already low and it puked out the overflow. That night after work, I drove home, shut the car off so I could use my key to open the garage and when I tried to start the car to pull it into the garage, all power
