Homehttps://www.facebook.com/groups/272473382858001/https://www.facebook.com/groups/272473382858001/1mz build and install blogToyota MR2 Message BoardvBulletin®vBulletin Skins by Bluepearl Skins
trany, gears, fluid, fill, dexron, higher, rpms, normal, change, confused, moving, valvoline, changed, gear, s54,i, liter, time, slip, frist, forwards, question, press, properly.do
- Ok i changed my trany fluid for the frist time on my 91 mr2 2.2 liter S54,i put in valvoline 75 w 90 gear oil & know when im in gears and press the gas it seems to slip before moving forwards properly.Do i use atf dexron instead or did i some how over fill it if that is even possible? :confused: when you add 75 w 90 do i need to change gears at higher rpms then normal? please help
